Can anyone help ?
Discussion in 'Rocket III Resources' started by Tattoomick, Apr 13, 2019.
Tags:
  1. Tattoomick
    Tattoomick Tattoo mad
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    2013 Triumph rocket 3 roadster
    Hi guys and girls, I would like to pick your brains and knowledge, I have a 2013 r3r I have just put ramair, tors, and link pipe on did the 12 min tune and on decel it is popping like crazy, I have called my Dyno guy but can't get me in till mid may, so just ordered a cable for tune ECU from lonelec, does anybody have a tune I can use for this set up. Thanks in advance all. .
  2. R-III-R Turbo
    R-III-R Turbo Warp Speed: ENGAGE
    918
    Featured Threads:
    22
    Media:
    85
    1,425
    203
    Ireland
    Ride:
    '10 Supercharged Carpenter'd Roadster, 04 Hayabusa
  3. Tattoomick
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    Thanks I will look into it, I'm waiting for cable to come once it does I will see how to use the tune ECU for the bike, much appreciated.
  4. John Miller
    John Miller .060 Over
    Country:
    Australia
    128
    Featured Threads:
    2
    131
    53
    Brisbane, Queensland Au
    Ride:
    2011 Rocket 3 roadster
    Guys the tune I have is as noted below:
    20355 Baseline Dyno Tune 2011 - Thanks @Martin_Brighton_Uk I don't know if it will be compatible your 20733 ECU.
    You could copy the tables and paste them across and see if it will copy, Tune-ECU will tell you if it is compatible or not. You also need to set the secondaries at 100% and copy the entire ignition table.
    Don't forget to balance the throttle body's and do an ISCV reset. The O2 sensor is off - leave it off or the tune won't work in fact remove the O2 sensor and plug the fitting.
    It has a safe AFR - wideband O2 sensor used to validate.
    It is a little thirsty with this tune (using an extra litre+/100km over stock) but hey I didn't buy it for fuel economy.
  5. Tattoomick
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    Thanks john miller, I will have a go with This when cable comes. Much appreciated.
  6. Tattoomick
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    John miller I tried to put tune in but no joy, my vin is above the 5 something it's in the 6. Looked
    Hi John miller tried putting tune in but no joy, my vin is above the 5 something it's in the 6s , downloaded the map in my bike and it is 20776 map. I other tune I can use? Ramair, tors , link pipe. Thanks.
  7. John Miller
    Country:
    Australia
    128
    Featured Threads:
    2
    131
    53
    Ride:
    @Tattoomick Yeah I thought as much - its not easy if you don't have a matching tune.
    There should be a matching tune in the resources section that will do the job on your machine let me take a look for you.
  8. John Miller
    Country:
    Australia
    128
    Featured Threads:
    2
    131
    53
    Ride:
    @Tattoomick You should try this tune
    Hans0 tune for 2014+ Roadster, TORs, triple/Ramair filters, ect.
    It is a 20776 tune - from reports on the dyno it is a good baseline tune, just go to the resources section and download and compare to your existing tune in TuneEcu you will see the raft of changes.
    That should work well for you bro.
  9. Tattoomick
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    You are a absolute star you is bro the world needs more people like you in it. How do I get that tune ? Thanks pal.
  10. Tattoomick
    Country:
    United Kingdom
    92
    Featured Threads:
    2
    93
    28
    West Yorkshire uk
    Ride:
    Got it pal , thanks
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
