Ridefree
- Joined
- Jul 11, 2012
- Messages
- 352
- Location
- St. Petersburg, Florida
- Ride
- 2013 R3T .... 2003 Harley softail
Hi All, I just want to find out for sure if I can remove the center bolt that holds the spring against the tensioner plunger without having to lock the cams down as long as i don't remove the body. From what I've read on this forum it sounds like the ratchet will hold tension on the chain even if the center bolt and spring is removed. I am hearing some chain noise between 1200 - 1300 RPM when cold on my 2013 R3T w/ 12500 miles on it. I was thinking I would check the plunger depth and and push on it lightly to see if it would go to the next ratchet tooth. Can you guys tell me if I'm thinking along the right lines on this and understanding this correctly.
Thanks in advance, Ridefree
