Navigator
I recently acquired Regulator's standard R3 bars and am going to install them on my 07 R3 Classic with Rivco risers. My present setup is classic bars with the auxiliary fuel gauge/clock and mounted with Rivco risers. I had the dealership in Pensacola install the Rivcos which necessitated rerouting the cables behind the triple tree. The owner asked me at the time if I wanted him to cut the cable routing stays in the front and thankfully I said to leave them.
It appears that the cables will have to be rerouted back in front of the top clamp/triple tree because the cable "reach" with the standards and Rivcos is probably close to the classic bars without the Rivcos. I don't recall how they originally routed though. It appears that the throttle and clutch cables should go forward of the top clamp but that the electrical cabling from each control housing plus the front brake cable should stay routed to the rear.
Question: Are the clutch and throttle cables the only ones routed in front of the forks?
It appears I'll have to remove the fuel tank for the first time to disconnect the throttle cables. I recall seeing a thread or two on fuel tank removal but I cannot find them and don'tt see a sticky on the procedure it in either the How To or Technical sections.
For those who have disconnected the throttle cables, is there anything tricky about this procedure or some special care I should use? I'd appreciate any advice on the control cable routing and fuel tank removal.
