Problem was found. Talk about a pita... I noticed that once the purple green wire had power (which it shouldn't have with the brake switches removed) and I grounded that wire, the bulb would shut off. When I jumped the orange wire on the rear brake connector to the purple wire, the bulb would come on and stay on. Ground the purple wire and it would go out and stay off. That made absolutely no sense to me, since there is no energy storage device on that line.
Well I decided to go old school and wire up a little buzzer to the purple green wire and the ground. I started shaking the harnesses starting at the handlebar. Nothing, still buzzing. Then I went to the relay area on the right side, nothing. Then I grabbed and twisted the wire that runs to the rear brake switch. Bingo, the buzzer cut on and off, I knew right then there was a short in that wire. I pulled it out and low and behold, there was a hole outlined in white in the loom. I pull the wires through and they were melted together. I cut the bad part of the harness off, and I will be completely redoing the 2 wire harness tomorrow.
Either it chaffed through on the backsidE of the engine causing a short, or the heat in that area caused it (doubt it). I will be routing it better and using double wall sheathing+ wire with more sheathing. I will post pictures tomorrow since this could become a fairly common problem.
