Well it finally happened, I dropped my bike the other night when leaving work, because I forgot to take the dammed disc lock off. Strangely enough there was very little apparent damage, a bent gear lever, tip of the clutch lever broken off, and a scratch on the mirror stem. The bike didn't cut out as I expected it to, but easily solved by the big red switch. A work friend helped me to lift it back up and I thought I was good to go but then found I had no front brake, well I had when I pumped it but when slowing down from walking pace there was a very noticeable clunk from the front brake. I found out that the previously mentioned dammed disc lock had bent the brake disc, so it was pushing the pistons so far back that the brake level came to the bar when first used. The ride home with just a rear brake was a little nervous
I don't know if it is safe to drive with just one front brake disc working (the other caliper is now strapped to the fork leg with something solid between the pads), so I need a new RHS front brake disc.
Does anyone have the part number of this disc?
