jasondon
- Joined
- Jun 27, 2012
- Messages
- 18
Hey guys, wondering if anyone can chime in on this. I did a search and didnt come up with anything.
My bike is still under warranty but I thought I would check here first. The rear brake caliper is leaking/seeping a little bit of brake fluid after I use the rear brake. It isnt much, but enough to wet the area around the bleed nipple. I checked to make sure it was snug, and it is. It is leaking as if it were loose because it appears to be coming from the threads, but its definitely snug. The brake appears to be working fine.
Any thoughts / ideas would be appreciated before I get it booked into the dealer to let them check it/fix it under warranty.
Cheers,
Jason
Cheers,
Jason
