Plow Horse
I ran into a bit of an annoyance yesterday after switching my indicator bulbs to LED’s
(2017 Roadster)
I swapped out the rely to CF13 GL-02, and installed 1156 base LED’s
Turned key to on position and tried the blinkers. Everything worked as it should, turn signals flashed at a normal speed green indicator light on the instrument cluster blinked as it should. I’m thinking great that was simple. Then I start the bike and try the turn signals, they flash properly but the indicator light in the instrument cluster no longer blinks it just stays on constantly till I cancel the turn signal.
Key on engine off everything works fine
Engine running turn signals work fine, instrument cluster light doesn’t blink
Anyone have any thoughts on this?
(2017 Roadster)
