it might be your turn to help me do that next! lol...did you get the bike sorted out?
Yes I did thanks ! It felt a bit like defusing a bomb at first , waiting to press a wrong button and erase my Ecu , but with warps patient guidance I found it not to be too bad in the end .
All was well until I balanced the throttle bodies which was easy enough , the bike ran great after which except for the idle became terrible , she would stall at junctions and bog down starting from hot plus the decel popping at low rpm was awful .
Then came the added problem that the tune ecu point blankedly refused to connect .
With Warps help I got the tune ecu connected and then ran the iscv tests , the figures were not wildly out but I finished up with .60 and .72 respectively , hit the reset adaptions and then ran the 12 minute tune a few minutes later . Results , idle fixed and smooth , no more stalling , hot starts faultless and decel popping greatly reduced !
Two things I would advise , with adjusting the stepper motor nut , I found easier with the bear claw removed and the coolant reservoir unbolted and hung out the way with a bungee strap . It can be done with all in place but you gonna need a stubby 7mm ring spanner ( box wrench to you mercans ) and the nimble fingers of a harp player ! Secondly , get tooled up properly for the Torxs screw on the tps with the correct torx bit . Its a bugger trying to hold the required .60 whilst tightening the screw !
As warp pointed out , there is a smidgen of leeway regards the .60 and .72 but being anal mine had to be spot on . Hope this helps .
