Best map for rocket classic 2008
headless74
Standard Bore
Rocket Classic
Hi, I would know which is the best map for my rocket without cat.
I upload the 20221 and i disabled the O2 but I think is better the 20219.
what do you think about it?
What are the differences between the classic maps and the normal rocket ones?
I though the engines was the same..
thank you in advance ;)
The tune in my signature sure works good for my 2006.
Look here CLICK
I would first ask if you have any modifications to the intake and or exhaust because what you are listing is stock OEM maps. Then a better recommendations can be made. Oh and if you ran any amount of time with the O2 sensor shut off its toast and should be considered just a plug for the hole.
I have only the nocat at the moment, I have the tor exhausts in the garage but for me is enough noisy like this.
I kept the same map but with the o2 on. It seems running better. I used for the first time the tuneecu android version. Very fast to connect ;)
