Getting a rear fitted tomorrow, wheel off, AV92 for $429 supplied and fitted, wasn't sure if that was a good price or not, SPM in Taren Point Sydney.
Good to see a 'real' tyre back on it
. Get the shaft drive spline and bevel drive cleaned and re-greased with a 60%+ molybdenum grease like this one:
LOCTITE ® LB 8012
contains 65% molybdenum disulfide for maximum lubricity.
It is a heavy, black paste with unsurpassed lubricating qualities.
I'm sure Wrecka did as he knew all about it and did as required including a few tyre changes. It is recommended to do every tyre change as the original factory grease dries out over time and some have had excessive wear etc because it was not done for extended periods.
https://download.schneider-electric...etin&p_File_Name=sds_081.pdf&p_Doc_Ref=SDS081
LOCTITE ® LB 8012
Known as LOCTITE ® 8012 or LOCTITE ® Moly Paste April -2015
PRODUCT DESCRIPTION LOCTITE ® LB 8012 provides the following product characteristics:
Technology: Anti-Seize
Appearance: Dark gray paste
LMS Cure: Not applicable
Application: Lubrication
Specific Benefit
● Provides smoother than new metal surfaces
LOCTITE ® LB 8012
Machine tool marks and other irregularities are reduced to a mirror-smooth finish by its lubricating action.
LOCTITE ® LB 8012 reduces friction on threaded fasteners, including bolts, nuts and studs.
The low and uniform friction coefficient of 0.06 creates reliable assembly conditions.
Lubricant stays in place through heat, load and vibration to ensure a trouble-free disassembly.
For the ultimate in low friction solid lubrication:
press fit - no binding, no chatter or stick-slip, low force;
threaded fasteners - higher clamping for torque, less torque for same clamping, ease of removal (anti-seize);
slip-fit - easy assembly, disassembly, ready alignment;
metalworking - drawing, stamping, coining, extruding, forging - lower friction, eliminates stretching, galling, metal pick-up, lengthens die life;
splines - reduces wear and binding;
gears - stands up under high static or slow-moving loads. This product is typically used in applications with an operating range of -29°C to +400°C
