Those pipes dont make the HP and lack tire clearance
Thing is Art - there are only afaik 6 THUGS - and just about every set is mated to a different set of headers - and in my case both the THUGs and headers (sort of a Predator/Jardine mix) are modified as well.
So saying "THEY" is wildly speculative. Which one of the half dozen different collector/tailpipe setups are you referring to?
Will mine allow 300bhp? - NO!. But they were not made to do so. My setup does deliver more mid range torque - which is exactly what I wanted and what I asked Sam to make mine to do.
On a standard 240/50R16 as spec'd by Triumph - there is adequate clearance. Gobbits of it (that's a lot in Olde Englishe)
As Ian says - only with oversized tyres is there a risk of contact (and here in Europe - illegal - The E-max would be an INSTANT on the spot fine if you were stopped as being outside € homologated specs). And yes our Guardia Civil traffic cops do carry abbreviated copies of what is legal and what is not, and calculators. And if in doubt - they call the DoT.
I know as they pulled the book out when the stopped me - for a different transgression - with a bloody lovely 680bhp Nissan. If in doubt they generally will not book you - but if they're after you - with an E-Max rear on - I estimate a 300 €uro fine. Oh and they were not in the slightest bit worried about the C/T - so that by precedent is LEGAL here. They have photos/details of the vehicle as stopped and cleared it.
And yes they called the DoT for clarification on one or two other things - like different indicator lenses, and LED vs Halogen clarification. They learned - and so did I as a result - all clouds have silver linings. Cost me €100 for being a naughty boy but I saw it as a consultancy call.
My lightly oversized (but with the 3% legal range) just brushed/polished one tiny bit despite having clearance when stood still. 2 * 8mm holes - slight trimming of the wire/lead gasket thing and I've gained 10mm MORE clearance with no hassle. Something one has to expect to play with on a ONE OFF pipe about 5000miles away. My mistake was not looking at it earlier.
And what the F*CK this has to do with a replacement 140/80R17 front - which YOU already know benefits handling - iirc was you who first tried a 140/75.
Thing is I can LEGALLY ride with a 140/80 and NOT a 140/75 - the law's an ass - what can I say.
