Scuba Craig
Just doing a bit of pre-planning while my auxiliary power socket is in-transit.
The instructions (http://www.triumphinstructions.com/ProdDocs/A9938047-EN.pdf) state ...
My question ... is the connector in the first pic below the one I am looking for? The plug doesn't appear to be correct to just fit to the back of the new power socket. I'll happily change the connector over if need be. But I'd rather not butcher that cable if it is there for some other purpose. And if not, where is the connect referred to in the instructions?
Thanks in advance.
Pic 1: Behind the left-side panel.
Pic 2: close-up of the connector
Locate the two-pin electrical connector marked with blue tape in the main wiring harness. The connector is situated in the area which was covered by the left hand frame infill panel. Fit the connector to the back of the auxiliary power socket.
Thanks in advance.
