Bondysbike
Turbocharged
ok...idiotic question...maybe....I just read the PCV AT instructions carefully again. With regard to accepting trims it mearly says ‘ To accept trims choose ‘accept trims’ from the drop down menu. ‘The trims are then sent to the PCV and the changes are made to the map’ or words to that effect.
I was trawling through all the posts here and they say ‘ once you accept the trims you then clock ‘send map’
Well , the send map bit is not called out in the AT instructions. SO...If I’ve simply been using the drop down menu to accept trims...and that’s it. ( ie not then clicking ‘send map’) Does this mean that actually it’s made no flipping difference because I did not then click send map?
Bikes running good but I keep having cells with high adjustments / trims and they don’t seem to be coming down so I think by just accepting trims and not then pressing ‘send map’ I’m simply doing sweet ‘fanny Adams?’
Thanks again all....
