Aregg
- Joined
- Apr 24, 2021
- Messages
- 26
- Ride
- Collecting my Rocket 3 GT next week, also a Honda
Rode my 2021 US Rocket 3 yesterday for 35 miles, stopped for about 15 minutes came to start it and it would not. I did not have the Key fob so thought maybe I am not getting that standard key in correct position. Bright sunlight so could not see the red light, and a lot of noise around. Anyway after a few tries it started so came home.
Came to start it today and it behaved as if the battery was totally flat, everything came on but when I pressed the start there was a click and all dead. Same exact behavior as a low charge battery.
All my toys are always on battery tender but the possibility was that maybe I had a bad battery.
Hooked up to a tester and the report was perfectly fine battery and 99% charged.
Turned the main switch (US Model) on and off. No luck, rocked the bike no luck.
Held the bike upright retracted the side-stand and it started immediately.
Bad side stand switch? Makes no sense it should only cut off if in gear. So tried it, no it would not start but the lights and the display did not dim or go off so can not be it.
Bike has about 1100 miles on it. Once OK the starter engages and starts the engine, if I turn it off and try again same story no problem.
I hate intermittent issues, it translates to a very long time at the dealership.
Any ideas, any other with similar issue?
Anyone managed to roll start one of these monsters?
