Here's the bike mods to start
14 R3R
Triple Air cleaners
Custom Headers hooked up to original collector box and running into 2 TORS
Map thats loaded is for K&N triples and Tors
Through winter the bike has run great only a slight burrble on change down from 3rd-2nd no back fire , had the occasional pop back through the throttle bodies but that had happened from the day i picked it up brand new.
Yesterday went for a ride through crawling traffic on a relatively hot day for around 40 mins , as i changed down rolling up to the lights i had one allmighty backfire through the middle throttle body that blew the filter most of the way off. After this happened it started backfiring though the exhaust , not big ones just little occasional pops on change down. I then rode 40klm on the freeway and the bike ran fine , no issues.
After being at a mates for 2 hours , went to start the cold bike and it was a bit hard to start , once it did start the idle was a bit off and kept giving the occasional small pop through the middle throttle body , once on the highway with the engine warm it was running ok , got home without any popping from either end.
This morning i again started it and it's still doing the pop through the middle throttle body on idle !!
Im taking a stab in the dark here and guess/hoping it's a stepper motor / idle adjustment and new map needed , im freaking hoping i havent got a ****ed valve , looking for some ideas where to start checking things starting with the obvious/easiest first
14 R3R
Triple Air cleaners
