I installed the triple K&N's on my 07 Rocket 3, but can't install my Pred exhaust until I get my gaskets from Triumph Is there a good tune to use until I install my pipe for full power in all gears? Thanks
I don't have any idea how lean you would be running with that set up. I would just keep the standard tune for now. Hopefully it won't be too long before you get the gaskets. Are they the copper ones for the exhaust port? Have you modified the tune you're running for full power?
to open 100%, and corrected the speedo. I think the gaskets are copper. I ordered them thru bike bandit. I hope they'll be here by the end of the week.
Click on the I4 tab, then up top click edit then copy table, then click I3 tab, click edit then paste table, click I2 tab, click edit then paste table.
That'll help for sure! I did it manually earlier. I was unable to do the 12 min. tune, as the bike kept shutting itself off after 5 minutes or so. The bike is def. more snotty. Wacking the throttle going slow down my street in 1st gear gets the tire in the air now. Now if my gaskets would show up, I could get my Preds on
