leatal
Turbocharged
Looking for a shift light and came across the Speedhut's SST-MAX-OBDII. Says it plugs directly into the OBD connector so basically plug and play. E-mailed the folks at Speedhut to check capability with our Rocket and of course their reply was "?????, you'll need to find out if your vehicle uses OBDII". However the website claims it is capability with all 2008 and newer vehicles and: "Works directly from the vehicles ECU using the CAN (J1979) protocol". Does anyone know if it will work with our bikes?
