Kevm
.040 Over
Despite reading the manual, instead of the drain bolts I removed one of other two smaller plugs in the sump. It did a pretty good job of draining the crankcase. I assume this is not a problem; I can just refit it, maybe with some thread lock? I can't find the torque setting in the manual so I was thinking 25NM like the proper drain bolts?
BTW I don't know which mouth breather fitted the filter as was a compete pain to remove. The proper filter socket or a chain wrench couldn't budge it. In the end I drilled a 1/2 inch hole through it and used a bar; even then it wasn't easy.
