Ishrub
- Joined
- Feb 18, 2016
- Messages
- 8,857
- Location
- Ride
A story from facebook of a beautifully restored early 2005 with gear damage I have not seen posted here before. @warp9.9 may be able to provide a cause/analysis. Makes me feel glad I only had the shattered teeth of one 4th gear in my sump and no grindings!
Split the case, parts replaced as seen below: 2nd gear, chewed up 3rd & forth, and of course all circlips, washers etc. Cyl head, (destroyed cam journal), oil ladder, both cams, bolts, timing chain, spark plugs, all gaskets. Thank God for eBay! Valves lapped (you'd be surprised how bunrt and pitted your exhaust valves are) and adjusted mostly to mid scale tolerances - a ton of work achieving that, and new valve seals to boot. Output shaft bearings.
