Advice on slowly upgrading a low mileage o5 engine to a demonic beast one day?
Rocketeer4life
Built like a rock
Pennsylvania
2005 Rocket 3
So my 05 r3 standard engine has a chewed up second gear rattlin round inside but otherwise is still a strong unit, with only 16-17k miles on it. Its out and a 14 roadster unit took its place. Anyone have thoughts of the tedious hastle/ minor cost of crackin into it myself to replace n fix is worth to even do or explore or Is this a perfect reason to now slowly build a pwer block?
No one seems to want to buy one o these engines with slight tranny failure. So if this seems as a good idea in theory, any suggestions to start off with building this thing back up while then open?
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
after the 05 there was several changes made
i like (others do not) the chrome valve cover and i think the timing chain and gears r wider.
problem with building an 05 is all the different parts. personally i would not build an 05
Rocketeer4life
Built like a rock
Pennsylvania
2005 Rocket 3
Well was goona crack it open regardless to replace whatever needs immediate attention in there. N why not from thar point on? Jus upgrade a recall here..lil there. N on track to throwing in/on select upgrades to be determined
TURBO200R4
TUCSON AZ
I would see whats wrong with trans then make up my mind if i want to spend that on a spare motor.
dont junk it that valve cover and timing chain and gears should be worth a few bucks.
Rocketeer4life
Built like a rock
Pennsylvania
2005 Rocket 3
Well thanks for some insight. Def woulda never been junkin. If no one wants this opportunity of potential. Meh il jus further poke around on it
Rocketeer4life
Built like a rock
Pennsylvania
2005 Rocket 3
you wont be able to do this slowly, the addiction is overwhelming and your family will be plotting an intervention, So, throw caution to the wind and go for it. 😁 (Before they notice youre building a beast)
Haha yeah thats the right spirit brotha! Realistically tho even after replacing whatever outdated oem essentials in there... Been seeing biig numbers for kits. Only really looking to have a meaner bike than a busa in a sense- without goin over board( that sweetspot) plus jus the idea of some sorta turbo or supercharger assisting with pumpin out this power in nice. Lookin real forward to the sound of it
Possibly...lol
1olbull
Riding Motor Since 1950
Tacoma, WA
2012 R3R "Kong" - 2011 R3R "YurMama"
Part it out . . . . . BTW I could use a gas tank? o_O
