I swapped the louder "accessory" cans back to the standard ones to see what difference there was to the noise. Maybe 25% quieter, but while doing the job I found the standard cans are 4kg heavier (each) than the loud cans, at approx 12kg compared to 8kg for the loud ones, and I guess that must be the cat. You can see straight through the loud cans when holding up to the light , they seem to have a slightly angled perforated pipe inside, about 35mm dia right through, so unlikely there's a cat in there?. You can't see through the standard cans .
So as I've got the map loaded for the loud cans i'll just swap them round at will, when I need to be quieter.
It would be good to find a lighter set still though, all that weight at the rear end must affect the handling. A pity Foran are on the other side of the planet....
