Toddyboy
.040 Over
So the previous owner to my bike had a wiring harness malfunction happen and had to replace it .without the dealer telling him that there's a recall on the ignition switch headlight relay. I'm now going to be taking it in to get the recall done so that it doesn't ruin the new wiring harness .now I had to switch the final drive and the drive shaft a couple weeks ago when putting everything back together the ABS light came on. is there a way to reset this as I can't figure it out and the previous owner says that was the indicator that he was going to have a wiring harness fail cause the ABS light came on shortly before the harness failed thank you in advance
