scot in exile
I was on it a lot today,no luck.It somehow has become very rich at 1/4 throttle and below.Tried Carpenter but had to leave a message.May not hear from them until next week.I am out of ideas,all is well according to the Triumph diagnostic tool,but not having an 02 sensor,i'm not sure what the ecu is thinking.John did say he could try to take a lot of fuel away at the bottom but that's just fixing the symptom not the problem.I guess it did run fine for awhile then started acting up ?Not really sure where to go from here unless Carpenter has an idea.Thanks,Dink
This nmessage is from my local dealer, story is I took my bike to a guy for mapping with power commander when I arrived the bike would not idle.
Bike has been running rich and starting to idle rough when shut down and starting back up, at the shop the guy(John) upgraded the new firmware to the PC-V installed new plugs (which were black) and still would not idle, took bike over to the Triumph dealer he put in a new TPS but as you can see from the above message not much luck.
Any ideas would be appreciated, as for hearing back from Carpenter I would not hol;d my breath.
