UNIVEGA
Standard Bore
2020 Triumph Rocket 3 R
Ridden 500+ lovely miles and bike booked for 1st service in 3 weeks.
Went for a quick run at the weekend, approx. 50 miles and when i got home noticed oil on the final drive casting.
On closer inspection it seems that at some point during the ride oil has vented out of the final drive relief valve.
Prior to last weekends run, about a week previous, I had done 200+ miles with a 30 min breakfast stop and no issues then.
The most common reason for this seems to be overfilling but if that was the case surely it would of happened before now?
Bike is booked in with the dealer to investigate but it is bugging me. Anyone have any thoughts on what may be the cause?
Thanks.
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
I am looking at the pic with my phone so not very good.
If that gear oil looks like a milk shake then it has water in there and when it get hot it will come out of the went.
If that is the case u will need to change the fluid a couple of times.
As i recall this happen to another guy.
UNIVEGA
Standard Bore
Thread starter
Thank you for your response, I had checked out earlier threads and seen as you mention but this oil is pure.
Bike hasn't seen a drop of water yet. Dry rides only and a quick dust / polish 👍
Gregger
Top Fuel
Timmins, Ontario
2012 Rocket Roadster
My gut feel... it was overfilled at the factory. If not.... that vent could be defective. Not sure if it is a breather check type vent. If so, it would allow air in if needed but not allow the fluid out.
AzRocketman
Phoenix
2020 Rocket R3
Good morning,
A quick way to check If gear oil is over full. With bike level straight up with gear oil warm remove fill plug on side below the vent.
if the oil level is to high, excess oil will drain out unti level is at or below the fill plug. (Correct level)
My 2020 R3r, now with 330-miles on it. Was 16oz over full on engine oil level.
These fluids, I think are added/ topped off during dealer prep.
I read the manual, it wasn’t until the great feedback on this forum. That I pulled out 16oz of oil. 1/2 quart over full, would of been alot if it wasn’t for the dry sump.
I had a great sales experience at the dealer. BUT- These motorcycle mechanics work on several brands.
With something on two wheels, running down the road at highway speeds, I don’t trust anyone wrenching on my bike.
After the 600mile break-in service. I will go over everything performed at the dealership.
I will never go back to the dealership for Maintenance, good maintenance documentation record’s, is the only requirement for claiming warranty work.......
Again thank you all , for the great resources on the r3owners.net
TURBO200R4
TUCSON AZ
Good morning,
with a lot of oil over fill it will go into the air filter
16oz probably not?
AdBlock Detected
I've Disabled AdBlock
