I hooked up Tune ECU and now the bike will not start. Power stops at the starter relay. I tested it and it is good. Also, purchased another to make sure. Battery has plenty of power. Any help will be greatly appreciated!
Thanks for responding. The kill switch is in the correct position and the clutch pulled in all the way. Even tried putting up the kick stand and changing gears and back to neutral.
When the key is turned on it goes through all of the normal pre startup operations but when I push the start button can only hear the starter relay. I tested it and even purchased another. Tuneecu shows that it is good also.
I reworked starter and battery connections. Cleaned, di-electric grease. Battery fully charged with tender attached and headlight fuse removed. Installed fuse. Still no start. I am going to try and install stock map again.
