Does anyone know how long the stock brake line is from handlebar to ABS box and what fittings are used? I need a brake line made 7" longer than stock. Any genders who could help with this would be appreciated as well.
I don't know. My brake line routes down to a block under the tank that goes to the ABS block. I finally just took a piece of cord and routed it down the line and measured it.
This is the email response I just got from Barnett
The line comes integrated so no you cannot just replace the top line (please refer to the attached file) and I do not know of any company that is doing custom lines for there triumphs.
Ivan
I'm thinking the one way to go is the ABS off of the Thunderbird, I believe since the bars and risers are higher it would give you enough to raise the bars or higher risers on the rocket. My quest goes on.
Ivan
Dumb statement on my part I'm not awake yet I see its for ABS. How long did you get the front brake line. How much did this cost. I should be able to just to give them your order number, or are they familiar with what they will need to send me. And thanks for all your time and help I really appreciate it
