Martin-Brighton-uk
I've seen lots of ignition switch failure threads and Eastern Beaver highlight mod, but I'm not sure if I'm hitting the same issue. Got 2011 R3R, She's always been a bit lazy with starting, kinda press the button and it doesn't start to crank immediately, takes half a second sometimes, when today She won't crank at all. I've checked all the fuses and when I turn the key switch on, the clocks fire up, but the press starter button doesn't make her crank. UPDATE, I jab the button several times and she now cranks but is tempermental. It's running fine and the battery is good, could it be solenoid or starter button itself?
Sorry this comes up a bit and I see several existing threads but if anyone can chime in that would be top banana. Thanks captains!
Martin UK
Martin UK
