2007 Touring, missfire or kicking problem.
Discussion in 'General Tech Talk' started by Richard in Wales, Jul 15, 2018.
  1. Richard in Wales
    Richard in Wales .020 Over
    Country:
    United Kingdom
    45
    Featured Threads:
    2
    58
    28
    South Wales
    Ride:
    Triumph Rocket III Roadster.
    Hi
    Looking for help with a friends 2007 Touring.
    Its totally stock.
    Map 20367
    He has had it about 7 months.
    22000 miles on clock.
    History unknown.
    This issue started a month ago, occasionally it would cut out coming to a junction.
    Then it started missing and kicking at low rpm cruising, occasional backfire and a sharp click from under the tank.
    Under acceleration its all fine, pulls like a train.
    TuneECU - no error codes.
    I suspected an ignition problem, and bought new iridium plugs, air filter, 2 aftermarket coils.
    Stripped it down, found No2 plug lead open circuit, and spark track marks on the lead.
    Fitted new coil + leads + plug caps.
    The occasional backfire and crack noises have gone, but the missing or kicking is still there.
    Fitted the other 2 coils on their bracket from my 2013 Roadster.
    Still the same, so there was a problem with front coil, now sorted, other coils shown to be fine.
    So the big question, what's wrong with it?
    Pictures show: -
    One of the plugs, they all looked the same
    Dissected plug cap, showing burnt 5K resistor
  2. Tripps
    Tripps Retired superhero
    Country:
    United States
    4,069
    Featured Threads:
    31
    5,244
    823
    Florida and NY
    Ride:
    R3T,Sprintona,K1200,r65,cbr1000rr, Blackbird
    I have the same issue, hopefully have a fix next week, ignition switch went bad on mine, when it does that, try wiggling the key. On mine that fixed it immediately, or killed the bike like a kill switch, it could go either way. Pretty much nailed it down for me. Do you ever have an issue turning the key on, no power ?
  3. warp9.9
    warp9.9 Pocałuj mnie w dupę
    7,896
    Featured Threads:
    9
    Media:
    14
    8,757
    823
    Forest City Illinois
    Ride:
    07 Rocket
    First clean and crimp with needle nose iers the low tension leads to each coil. The front one is a bugger to get at. Take the plate mounted above it and toss it. Just to be clear here is a picture of number 2 coil and the proper wire location. Each is the same.
    Disregard the blower intake plumbing as you might not have that style of air filtration. :D
    Boog and Tripps like this.
  4. Richard in Wales
    Country:
    United Kingdom
    45
    Featured Threads:
    2
    58
    28
    South Wales
    Ride:
    Hi
    Thanks for the replies.
    Ignition key appears to be fine.
    Coil terminals - all checked and tightened.
    the what?
    Thanks
    Richard
  5. Jvheli
    Jvheli Supercharged
    Country:
    United States
    410
    Featured Threads:
    11
    560
    103
    Milwaukee, Wisconsin
    Ride:
    2016 Rocket Roadster
    How about the three map sensor vacuum lines under the tank? They are very critical to the ecu for fueling. A leak is gonna cause problems. Also, if you decide to replace them they are legnth critical
  6. Jvheli
    Jvheli Supercharged
    Country:
    United States
    410
    Featured Threads:
    11
    560
    103
    Ride:
    @warp9.9 is refering to the steel plate mounted atop the front coil. Triumph put it there to restrain the mass of wiring there. It also serves to make reinstalling a total pita!
    warp9.9 likes this.
  7. rash_powder
    rash_powder Supercharged
    Country:
    United States
    226
    Featured Threads:
    14
    Media:
    3
    106
    43
    Larimore, ND
    Ride:
    2008 Triumph Rocket III Touring
    I have been battling a very similar problem with my 2008 Touring. I haven’t had opportunity to double check it, but I think I have a bad MAP sensor - the under tank unit, not air box.
    Tune ECU will help you diagnose. Last I had mine running my MAP indicated the same Pressure running as not running.
Loading...
  1. This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
    By continuing to use this site, you are consenting to our use of cookies.
    Dismiss Notice
