Joseph James
Dunnellon Florida
2000 Thunderbird, 1200 Daytona SE
My 2007 Rocket 3 developed a issue with the Power Commander 3 that was installed and tuned 12 years ago. Intermittently the bike would stall and run rich. I disconnected the CP 3 and reconnected the wiring harness but forgot to reconnect the O2 sensor. My bike has a K&N air filter, cat delete pipe and a Raask 3 into 2 slip ons. Disconnecting the P C resolved the problems and the bike runs just as good as it did with proper functioning PC. Is it ok to run it this way? There isn't any engine codes. Any ideas?
Thank you, Joe
TURBO200R4
stand up straight and grab the world by the a$$
TUCSON AZ
07 rocket III classic
PC = power commander
did u hook up the o2 sensor?
does it have the CP o2 replacement bung (forget what it is called)?
i think that u should take it to a tuner.
Bull
.060 Over
Saline, MI
2007 Rocket III Classic Tourer
I am having the exact same issue with my '07. hope someone has an answer.
Idaho Red Rocket 3
Nampa, Idaho
2006 R3 Standard Bagger w/Fairing
You need a proper tune but there are several custom canned tunes on the TuneECU website. At least get one of those downloaded as your stock tune now is far too lean for any long term use. A dyno tune is best but one of these canned tunes is good enough for now.
Joseph James
Thread starter
Dunnellon Florida
Nope. Figured if the ECM got a input from O2 sensor the bike would run to lean. No engine light so ECM is not missing the O2 sensor? No after market O2 gizmo. I read somewhere that a missing O2 sensor will make the fuel mixture rich. Maybe the mods I made have corrected the fuel mixture . I'm going to take my Rocket for a ride and check the color of the spark plugs.
Joseph James
Thread starter
Dunnellon Florida
I had a idle problem away back and resolved it by pouring a whole bottle of Lucas fuel system cleaner in a tank of gas. Eight bucks for 5.6 oz of stuff seemed expensive but it worked for me. Add the elixir take your bike for a short ride and let the bike sit for a day or two.
Bull
.060 Over
Saline, MI
I had mine dyno’d and it worked well till this year. For example if you let it idle till warm it chokes and stalls, smells like it was running rich.
Joseph James
Thread starter
Dunnellon Florida
Sounds like dirty fuel injectors. The fuel injectors are designed to spray the gas as a fine mist and dirty ones spit the gas instead making the engine run rich as it warms up. I poured a whole bottle of Lucas fuel system cleaner in a tank of gas
AdBlock Detected
I've Disabled AdBlock
