skydog1000
Working on a 2006 Roadster with a dead spot at about 4000 RPM. Does not matter if it's in 2nd or 3rd gear. The bike has three K & N air filters a carpenter Sidewinder exhaust and a HansO tune. I have already replaced the vacuum lines and tightened the low tension leads put new plugs in replace the secondary TPS that helped. Has anyone ever had this happen to their 2006 Roadster or any other Roadster that it has a Miss at about 4000 RPM if you do what did you do to fix it. Bike runs great other than it has the miss it just like it stalls for a second and then goes back to running fine.
