Bill Stone
Standard Bore
So I have a 2005 Rocket with 12,346 miles. It has been run 3 times this year with no issues... (tank topped off once... so probably a 50/50 split of new/ old gas.) Then a week after the last ride it will not start... It cranks over but will not start. I have checked.... fuses, relays, tip over switch, that the fuel pump is pumping.... but not pressure tested, just that when turned on fuel is pumped out of the hose, pulled apart many of the connectors, disconnected battery for a bit.... With a quick shot of ether it starts immediately... so I am not getting fuel... any thoughts? Dealer can't look at it till July 13th.... :-( So are there any other sensor I should be looking at that would effect if and when the injectors come on? or any other ideas to go after.... it was running fine now and suddenly its not.... so I keep thinking failed sensor/ black box....
