Jascen
Shawnee,Oklahoma
2005 Rocket 3
I got a 2005 rocket, but has an intermittent high idle problem that has now become more prevalent. I talked to a tech at the Triumph dealership in Oklahoma City and he informed me that in order to replace the primary TPS I had to replace the throttle body..... I'm not too sure this is true, any advice? Can I just order a new primary TPS and install it and adjust it with TuneECU?
baadactor
Bar Harbor, Maine
'05 Rocket 3
Not true.
1K9
No'mo Rocket 4 me
Clear Lake / Houston, Texas
Honda CB1100
Unbelievable
DaRiz
If I give a chit....You'll know
Pea Ridge Arkansas
2006 Rocket III Classic
I had the same trouble on my '06 classic. Here's what worked for me.
Pulled the rear Throttle Positioning Sensor, put it up on my bench. It's a simple potentiometer. Set it face up (flat blade screwdriver type socket), spray some WD-40 into it, cycle the pot several times with a small flat blade, this cleans the wiper and circuit. Re install in the same position that you removed it.
Adjust the rotation for the best idle speed, one way kills it, the other high revs it.
Not that hard if you're mechanically inclined. I've been riding it just fine for a couple years now. I think it picks up grime from the road.
Don't be skeered, and don't fall for lousy mech's that advocate jacking up the radiator cap and parking a new bike under it.... new throttle body.... That guy needs to work at Crispy Creme!
sonny
Henryetta Oklahoma
rocket three x
Welcome from the big city of Henryetta Oklahoma. Home to no. 74. The dealerships in Oklahoma suck. Untrained and just plain goofy. Oklahoma city dealership can not even change a back tire without screwing it up. :(:(:(:(:(:(:(
TRIIICK
Plymouth Massachusetts
05 Rocket III 01 Roadking 08 Busa
