Karl Tyrson
greeting. I just bought the Lonelec lead and dwd tune ecu. Mine is a 2005 Rocket 3. I have the next mods on it:
-cat gone
-KN air filters
-3-1 pipes with 2 brother´s carbon exhaust tip
-secondary throttle flies gone
I live in Mexico City so there are many issues about it, being the first one the media height above sea level that is 2250m, and I believe it is quite poluted. then that there is from few to none information or triumph specialist nowhere, so it is quite difficult to find parts, service or support.
the tune ecu provides that the map is the 20050
I would be very thankfull if you could help me out on this. I am downloading the maps from tune ecu page, and have installed the windows program as I am a iphone user and did not buy the android cable from lonelec when I had the chance.
just installed the 20226 and it scared th s out of me as it wouldn´t start after all the process, it ran and instantly went off. like for 10 minutes like that. then plugged back on tune ecu and used the reset adaption and it went on but felt a little rough. ran it about 8 minutes after fan went on and it shut down. Had to start the bike again and it ran more or less ok. I took it for gas and though it won´t feel rough, it felt slow response bellow 3000 rpm with over 80% throttle. the former map 20050 did felt more powerful almost from 2000 revs and up, it accelerated good without hessitation. should I install the 20050 map again? or is there a map that can squeeze the full power with the mods done?
-cat gone
-KN air filters
