12V aux power socket
Ollie
Standard Bore
Triumph Rocket 3R
How you managed with that 12V aux power socket above clock; for navigator, phone power supply ,etc? Any "USB adapters/cables available that socket?
I have this on my R3GT. Works great for GoPro and Phone.
Update: The one above is a POS. It failed on me after half a season.
With over 15000km while using this one I recommend the "Cllena DIN Hella Plug to Dual Quick Charge 3.0 USB Charger Adapter with LED Voltmeter for BMW Motorcycle (Green)"
I got both of these the, one with the voltmeter i keep in the dash, the other one I keep under the seat for when I need to put in the ACC 12V socket below the intake manifold
I purchased the second adapter that qweesy777 identified:
I found that the adapter stops working periodically while riding. When it happens I jiggle/twist the adapter in the socket and then it works again -- until the next time that it stops working. I suspect that the adapter breaks it connection either from vibration, or when the road surface is poor (bumpy). Any ideas for a resolution?
I had the IMETSOU originally and it failed on me, almost exactly as you describe. It became intermittent then eventually didn't work at all.
I just finished a 6500km trip and have been using this one for well over 15000km, Amazon.ca "Cllena DIN Hella Plug to Dual Quick Charge 3.0 USB Charger Adapter with LED Voltmeter for BMW Motorcycle (Green)". It's been excellent for my needs. I power a Quad Lock QI Charger and a GoPro MAX without any issues.
☝🏼 This! I have one that works great & charges my phone, but these smaller sockets don't seem to lend well to staying in while 'spirited' riding. I notice I have to push down on it from time to time when I notice it not charging. Trying to figure out how to get it to stay in. Anyone else have this issue & have a fix?
