rash_powder
hey all!
I have been battling a doesn’t want to start problem for a few days now.
Currently, it will crank and cough once or twice as though it tries to start, or maybe run on the starter, or start just enough for the starter to kick out and then die.
I have replaced the gear position sensor with the current kit, all spark plugs, recrimped coil low side wires, cleaned the crank position sensor, reset ISCV several times, and exercised just about every connector I could find.
After I did all that tonight it started and ran long enough to complete the 12 minute tune and for me to get some data for the pcv-at pressure setup. At about 20 minutes of idling beautifully it shut itself down and will not start again.
Is this the TPS?? Tomorrow morning I will remove it and check the color of the insides and then reset it all and see if it will run again.
I’m at a total loss as to where to go next.
Other symptoms are my pc-v quite regularly loses sink with the crank position sensor through the injector harness. Throttle body balance when warm they are all within 20 of each other - I know it could be better but that is awful close - it will be addressed when it will stay running. Stepper motor does move - I saw it extend quite some distance out at a reset or start test, I don’t recall anymore. MAP values seem to be the same wether it is running or not. I do not know if that means anything or not. Based off the throttle body sync in the manual it should run without the MAP connected so I’m not sure if it being faulty would be trouble. I haven’t seen any error codes either.
If anyone has any ideas I would be forever grateful!
