hi friends
my current ecu tune is stock 20226.
I'm looking for tuneecu tune with good performance on 1500-4000 rpm and
with max saving health of the engine
bike used as power cruiser for long travel
hi friends
thanx man
is fully tested and approved tune?
i do not need the maximum performance on the dyno
I need a comfortable driving and masterful acceleration for overtaking traffic without performance reduce on 1500-4000 rpm
and that the tune does not reduce the life of the engine and its components
using 95 octane
thanx man
using 95 octane
I approve it. I used it for years on my 2005 R3. It was made on a dyno by Wayne MacDonald in Australia. He invented Tuneboy. It does give better performance, an extra 12 ft lbs at peak torque (2500-3500 rpm). Peak HP (6000-6300 rpm) is only about 2 higher than 20026. None of this gain is really that noticeable so if you don't care about performance, why not stick with 20226?
i download this tune to the ecu and did a adaptation reset with tuneecu. i made a 12 minute training.
and i got my first bug on this bike:
i nicely ride 70km with biting acceleration on middle and stopped to wipe the windscreen.
started the engine and got a 2000rpm idle.
ride another 10km (sometimes normal idling was restored) and stopped to restart the engine.
the engine is started with the normal idle but stopping when i switch to 1st gear. i made 3 attempts to restart the engine and to go.
i wait 10min and engine started with normal idle. switching 1st gear and over gears happened without the engine stops and i ride another 10km without error to the parking.
what happened?
2000rpm idle - it is probably tps error. but why engine stopped when i switch to 1st gear?
what happened?
