Please don't take this as urinating in your Wheaties, but as something to be aware.
This style of intake is pulling hot air off the engine, after it has passed through the hot radiator. This can mean that intake temps can be 150°F or more.
Each 7.4°F of temperature increase results in a 1% drop in air density, and a corresponding drop in output. This means that on a hot Summer day where ambient temps are in the 90°F range, you can be losing 8% or more of output.
For instance, running three K&N RU-2780 air filters under the bearclaw, and then testing with the Bearclaw removed, results in a 3.7% difference in output with many full exhaust systems I have tested. Pulling all air from under the tank will result in a greater difference.
While this may not matter much to some, it is something others may be concerned about. This is why I bring it up.
