Paul Jacobs
Bald is best
I have recently taken the cats out of my standard Roadster exhaust. I have the new ram air filter installed. Everything else is bulk standard.
I am currently running the below tune with the map 20352-2 the guide info reads as follows.
My question. Is there a better canned tune for this configuration?
Rocket III Roadster Standard exhaust
* OEM adjusted for Roadster TORS, which means based on map 20352.
* fully open secondaries on all gears, all rpm
* Ignition tables copied to be the same on all gears, copied from I4 (I N) to I3 and I2 which means same ignition retardation on all gears.
* Top speed adjusted to 260 km/h - 162 mph
nothing advanced is altered, nothing that requires a dyno or deeper knowledge.
secondaries are just written to be 100% in the entire matrix
ignition is just copied from I4 (I N ) to I3 and I2, not edited in any way.
this tune runs on my bike, no problems. using TuneECU 1.6.6.
