In case anyone's interested. Bridgestone Excedra max 240/55 $157. Avon Cobra 150/80 VR 17 $140. Dennis Kirk. Free shipping sort of. $ 5 handling ea tire. My total for both was $308.
Unique wide shape of tire profile supports touring-type riding
Linear handling even for a heavy bike and 2-up riding is provided by the belt package construction
Purpose-built rubber compounds and tread patterns enhance water evacuation
Blackwall
Tubeless design
Safety Warning: Please consult tire manufacturers publication(s) and/or website(s) for information on tire care, safety, installation, maintenance, manufacturers warranty and other information. The tires used for your application must have a load index and speed rating equal to or greater than the tires fitted as original equipment
Sidewall ID Information:Bridgestone Exedra Max-R 240/55R-16 M/C 86V
Dimensions:
Inflated Width/Measuring Rim Width: 9.4"-8.0" Inflated Diameter: 26.4" Acceptable Rim Width (s): 7.0"-8.0 Deepest Tread Depth: 9/32" Balance Dot: One Yellow Directional Arrow: Yes Speed Rating: W (V270)-rated for speeds up to 168MPH
Capacities and Construction
Load Capacity/Inflation Pressure: 1168 lbs/43 psi Load Range: B Bias or Radial Ply: Radial Tread Plies/Material: 3 Nylon/1 Aramid Sidewall Plies/Material:3 Nylon DOT approved for road use: Yes Tube or Tubeless: Tubeless
Specs
Aspect Ratio 55 Construction Radial Position Rear Rim Size 16 Sidewall Blackwall Speed Rating H Tire Classification Cruiser/Touring Tube Type Tubeless Units Each Width 240 Weight 20.6 lbs
Above in red is the conflicting information I found in their product identification. I hope they actually have both they send you the right one.
