The clutch diffinately does changed something , here is what I was sent by the tuner-
The Hex map that was in the bike was close but had problems with the A/F at the top end. I have used Tuneboy and now you have three maps.
Map 1 is full power
Map 2 is Economy for cruising (only between 5% and 20%TP the rest of the map is full power)
Map 3 is full power (can’t tune for a wet weather map without the sec butterflies)
To switch between maps, stop the engine, turn the key on, stab the clutch 5 times in 2 sec’s and the tacho will oscillate once for map1, twice for Map2 and three times for map3. I have it set to always start on map1.(Every time you turn the key on the bike will go to map1), If this doesn’t suit you I can set it to stay on whatever map you choose until you change it again
This was all done before buying the bike ,the previous owner passed this info on.
