warp9.9
Pocałuj mnie w dupę
The TPS can go bad without creating a high idle problem. its basically a rheostat and can get a worn or flat spot in it that could cause a stumble or bad signal that would create a stumble. Since you have been messing with it could it be you have tightened it to much? Do uo have a shim under it so it stays flat and does not get cocked at a angle when you tighten it? The shim fix or mod has been out for years since the age of Homobre !!!! I believe he noticed the affect of it not setting flat when installed. This could very from bike to bike or throttle body to throttle body as tolerances creep in during manufacturing. I used a soda can to cut my shim out and have never had a problem with it since I used the shim 45,000 miles ago.
