dbutton12
.060 Over
This project actually began because I wanted to use the stock airbox for my amp. After looking over the filter/airbox possibilities available for the R3T I decided I would have to be creative. I have always preferred a symetrical look, so I started researching velocity stacks.....you know, old school but with the filter caps on them. What would look better than 3 exhaust on rt and 3 intake on left. That was not to happen, although i may experiment with that in the future. I settled on the chrome end, tapered filter pods from K&N (I just happened to have 2 of these left over from an old project, so I only had to buy one more) I did not build this prototype with aluminum because thin sheet aluminum is really hard to tig weld and I am not proficient enough to tackle it. So,,,copper it is....very easy to work with and only requires clean surfaces to solder it together. I have a bud who is a very good tig welder and may enlist his help on an aluminum version next winter. I guess looks really aren't much of a factor because so little of the airbox shows once the bearclaw is installed. It took a bit of time to get the openings correct on the bearclaw since I wanted to be able to remove it without lifting the tank. Initially I had it so that the claw was bolted in place then the tank (with claw) lowered into place. The tank is a ***** on the touring because you have to remove the gauge cluster before lifting. I relocated the rad expansion tank to the top of the cam cover (lots of room up there now) and fab'd a crankcase breather tube that plumbs into the back of the airbox. I don't like that idea of putting a tiny filter down at the rear of the engine because it can allow moisture into the crankcase (besides, the plumbing didn't cost anything and I was able to use the stock rubber elbow on the bottom end. The end result came out well and I am able to sit comfortably without having to hang my knee out to clear a filter. I uploaded more pics to the general file, so check them out if you have time and let me know what you think.
Dale
Dale
