tdragger
Scratching my head a bit on this one. Maybe you folks can help.
I've been running a version of the 20226 tune for several years with the speedo adjusted -5.5 percent and the O2 sensor turned off.
Last weekend, I read the map off the bike into TuneECU and set the speedo adjustment back to 0.0 and saved the map. I then downloaded it to the ECU. No other changes were made.
I reset adaptives as you should always do after loading a map.
Now a problem has developed when slowing down for a traffic light and pulling in the clutch the idle drops down to almost 400-500 for about 5 seconds before recovering back to about 900-950 where it should be. A few times the bike has died requiring a rolling restart.
Is this happening due to resetting the adaptives?
