albertaduke
former airline pilot without the big bucks
I am baffled I removed the rear wheel for a tire change and I tried ( lord knows I tried) to re install the rear wheel (2006 standard) so here is how I tried
I put the wheel in the drive ..all the way (used a jack to line it up) I can hear the teeth turning in the final drive meaning the wheel is all the way in the drive I drove the spline into the wheel up to the spacer put the spacer and drove the spline flush with the spacer now NORMALLY the rear brake mount should slide between the swingarm and the spacer well it does not 4 mm seem to be in the way that seems too much to be normal and I cannot force the swingarm open that much , I removed the wheel put it back several times still no luck the spacer is 29.48mm long it is the right size so where is the problem I sure cannot think of anything and I cannot put back the rear brake mount back on it will not slide between the spacer and the swingarm
I am thinking I don't need no stinking rear brake but that is another story
