jthree
Turbocharged
So I just changed my oil. Removed all three plugs and the filter. Replaced all of the above and proceeded to pour the new oil in. Started off with 2 x 1L jugs then a 4 L. Just before the 4L was empty (I was just about to stop) the oil came flooding out of the filler hole. Having run the engine for a minute and checking the level, it is way too high.
What could I have done wrong? The capacity id 5.9L isn't it?
Update...
Poured the old oil into the new containers. Only ended up with a little over 5L. Allowing for the fact that the level was a little low and I did spill some, I'm close but further than I think I should be. Any idea all the oil didn't drain?
What do I do now?
Update...
What do I do now?
