No Start Up Sweeps
Discussion in 'General Tech Talk' started by HeR3tic, Jun 11, 2011.
  1. HeR3tic
    HeR3tic Living Legend
    Country:
    United States
    3,471
    Featured Threads:
    64
    Media:
    29
    47
    748
    Heart of Dixie (Alabama)
    The dealer is stumped and has been unable to resolve the no sweeps at start up. And it has been progressive and alternating. Alternating or intermittent with whether the speedo would function at all. There may or may not be a functional speedo over a period of time but most recently it functioned, even though initially there were no sweeps with either the speedo or tack. Early on, speaking of progressive, the tach would sweep though that no longer ws the case. In other words, no absolutes. The dealer says no ignition switch issue. Their conference with Triumph has lead no where. Any suggestions?
  2. HellFire
    HellFire Legend
    4,547
    Featured Threads:
    61
    Media:
    32
    342
    783
    That was a symptom of my ignition switch failing ... other than that I've never had it happen before.
  3. Gothlander
    Gothlander 321 GONE
    Country:
    Australia
    806
    Featured Threads:
    16
    Media:
    1
    332
    163
    Gold Coast Australia
    Bad earth somewhere on that circuit.
  4. Lester532
    Lester532 Turbocharged
    Country:
    United States
    938
    Featured Threads:
    10
    Media:
    32
    187
    143
    Cottage Hills, IL
    I had that problem once with a blown fuse. But I hope the dealer would have found that by now.
    If I remember right the horn and turn signals didn't work. Weird.
  5. Molinoman
    Molinoman Living Legend
    Country:
    United States
    2,787
    Featured Threads:
    144
    Media:
    202
    270
    783
    Molino, FL
    Rides:
    2014 Triumph Rocket III Touring
    I'm with Hellfire on this one...if your ignition switch hasn't failed yet...it sounds like it is fixing to. Mine had those symptons for a couple of days and then..voila'...no ignition.
    You didn't mention while turning the key on if the headlights came on or not.
    Dennis
    13 dtg KAF
    15 dtg Dubai
    16 dtg Home for good!
  6. tdragger
    tdragger Living Legend
    2,786
    Featured Threads:
    83
    Media:
    36
    717
    813
    Fredericksburg, VA
    sounds like ignition switch. turn key on and move handlebars lock to lock to see if it makes a difference.
  7. fat frank
    fat frank Supercharged
    291
    Featured Threads:
    23
    6
    18
    Houston, Texas
    Lift your tank and move check the connection from the ignition to the harness. It solved my problem. BTW, they don't like water. Be carefull when you wash it.lol
    Later and good luck
  8. atomsplitter
    atomsplitter Nitrous
    Country:
    United States
    1,013
    Featured Threads:
    49
    201
    163
    Scranton, KS
    Don't pressure wash you bike, EVER! It's bad for every part of the bike. If you force water you also force the dirt carried by the water into whatever you're spraying. I've seen wheel bearings that looked like a grenade went off in the carrier because the guy used a car wash sprayer to wash his bike.
    More than likely you have a loose connector (or a corroded one).
  9. scowherd
    scowherd Top Fuel
    Country:
    United States
    1,535
    Featured Threads:
    37
    Media:
    173
    460
    283
    Louisville Kentucky
    Had the same problem try replacing the fuse that is labeled for the heated grips that also supplies power to the gauges. Also check the battery connections
  10. HeR3tic
    Country:
    United States
    3,471
    Featured Threads:
    64
    Media:
    29
    47
    748
    Turn signals, horn? Watt them fer :)
    Ive demanded the old/replaced intrument cluster be handed to me when I fork over 1300+ for the said causees. And possibly a speed sensor. +$$ more. I will spit lead if I get #$%^ed on this one!
    Let me be fair: Roger, serice manager, tried on a pair from elsewhere and the sweeps were on target. Whether yet to be determined if the speed sensor is also $#%^ed out well see.
Share This Page
Loading...
Triumph Rocket III
