ROCKETHEAD
Top Fuel
Figured I would start a thread on my 2014 R3 Roadster Build...
Highway Pegs from my 2012 Goldwing - done
Right side is a straight bolt on, the left side clamp needs to be grounded at a 30degree angle to fit on the slanted tube in front of the gear shifter
Fuse block with relay and 6 fuse-able leads - done
ran trailer flat wiring to the front of the bike from the battery area, this gave me 3 hot leads and a ground
used a 30amp relay and tied it to rear running light, ground, battery and fuse block
ran 3 fuses to the block and the 3 leads going to the front of the bike, the other 3 is for future use
Garmin Zumo550 install over gauges - done
Some ram mount bits I had laying around...
Corbin Backrest with Glove-box mount to stock seat - done
made up a bracket and adjustment screw to fit the Corbin shaft...
Corbin Beetle Bags - done
Evil-Bob Chin Spoiler - done
Evil-Bob Iron Maiden bug screen - done
J&M amplified speakers - working on it
Painting of all shiny pieces flat black - underway
Dog Rack for my security system/companion - underway
Quick detach passenger seat - underway
