DEcosse
If it's no Scottish it's CRAP!
So the Touring model has the Flasher Module built into the Instrument Cluster:
For anyone who has fitted LED Signals (or replaced the incandescent bulbs with LED type)
- Do they flash at 'fast' rate, or normal?
If they flashed fast, how did you resolve it?
With a 'Std.' or Roadster, it is easy to just swap out the Flasher Module (relay) to an electronic type (CF13GL-02)
Adding resistors across the lamps would be simplest I guess - you could wire in the external Electronic Flasher Relay but that is probably more mod that you would most likely want.
I'm mostly just curious on whether they flashed fast or std.
