just had cams fitted to my roadster fist start up fine then the next startup it run on 2 cylinders only should it be remapped be for looking for any other problems
No first check the low tension leads on the coils they work loose. you should pull them clean the coil connectors and re-crimp them with a pair of needle nose pliers so the go on tight then fire her up and check.
