I understand that all three cylinders should be similar in compression, what is a good baseline....I would guess around 60 would be way low....120 no way. There should be a ballpark number I am looking for. Even briggs & Stratton gives you a recommended compression number for the engines. The only thing I have done to the chain is remove the spring, measure the depth of the plunger, it was over 20mm. this calls for the addition of the spacer. I did that, it ran fine with no noise. Keep in mind, my problems did not happen all of a sudden, it did get worse real faast once I noticed a problem, I woulds say within about a mile of riding and two or three starts in the garage after that, now it won't even start.
